ChristinoDesign Posted June 18, 2020 Share Posted June 18, 2020 I'm working on recreating an existing window in my client's home, it's a small bay window that is set in the thickness of the wall. When I use the bay window tool, I'm only getting the window angle to start at the surface of the wall and not sure how to go about creating a 90 deg. sheetrock jamb, and then start the angle of the bay window. Any suggestions? Link to comment Share on other sites More sharing options...
joey_martin Posted June 18, 2020 Share Posted June 18, 2020 That looks like a BOW window, not a bay. Try the BOW tool. Link to comment Share on other sites More sharing options...
DzinEye Posted June 18, 2020 Share Posted June 18, 2020 You could adjust the Bay window (or Bow window) units as needed... tab select to modify and move each window in the unit... then use p-solids at the sides of the opening to create corners. This will get you the look in 3D, but the framing opening will need to be done manually if you plan to show framing. Link to comment Share on other sites More sharing options...
ChristinoDesign Posted June 18, 2020 Author Share Posted June 18, 2020 0 Advanced issue found ▲ Quote 2 minutes ago, DzinEye said: You could adjust the Bay window (or Bow window) units as needed... tab select to modify and move each window in the unit... then use p-solids at the sides of the opening to create corners. This will get you the look in 3D, but the framing opening will need to be done manually if you plan to show framing. Perfect - thank you! Link to comment Share on other sites More sharing options...
