skoz44 Posted June 16, 2020 Share Posted June 16, 2020 I have a set of drawings that the client has created a ton of changes, so I have a ton of bubbles. I'd like to create a note schedule to describe the changes. Ideally, I can have a separate Schedule for each page (floor plan, electrical, plumbing, etc.) and can use the triangle for all changes. The issue I'm running into is that I create the notes on the floor plan, when I goto the next page, the numbers continue in sequence and the second legend shows the notes from the first. What is the best way to accomplish this? Link to comment Share on other sites More sharing options...
steve_stuart Posted June 16, 2020 Share Posted June 16, 2020 Not sure if it is the best way but I create a new Note type (Electrical 2, Plumbing 2, etc.) and create a new Note schedule that looks at that Note type instead of the original. 1 Link to comment Share on other sites More sharing options...
skoz44 Posted June 16, 2020 Author Share Posted June 16, 2020 I think that's going to work well. Thanks Link to comment Share on other sites More sharing options...
joey_martin Posted June 17, 2020 Share Posted June 17, 2020 Use a revision index on the layout page. Link to comment Share on other sites More sharing options...
skoz44 Posted June 17, 2020 Author Share Posted June 17, 2020 Thanks Joes. Do you do all your revisions clouds on the .layout page as opposed to the .plan file? Link to comment Share on other sites More sharing options...
