RonChief Posted June 16, 2020 Share Posted June 16, 2020 Hello guys. I made a square column in CA and I want to represent it in 2D like a box with hatch in it But I can;t put a hatch because I made my customize column using the Box Shape. from Shapes Library Link to comment Share on other sites More sharing options...
rlackore Posted June 16, 2020 Share Posted June 16, 2020 Two options: 1) Use a Post, which allows you to define the fill pattern. 2) Draw a CAD square, then convert it to a Polyline Solid, which allows you to define the fill pattern. Link to comment Share on other sites More sharing options...
robdyck Posted June 16, 2020 Share Posted June 16, 2020 6 hours ago, RonChief said: Hello guys. I made a square column in CA and I want to represent it in 2D like a box with hatch in it But I can;t put a hatch because I made my customize column using the Box Shape. from Shapes Library For a column, especially a square column, I'd suggest using the 'Post' tool which can be found under 'General Framing'. Link to comment Share on other sites More sharing options...
