robdyck Posted May 22, 2020 Share Posted May 22, 2020 Is it really possible that the Layout Revision Table doesn't allow 1 revision entry for multiple affected pages? For example, I need to show a revision for pages 1-3 out of 4. If I place the revision table on page 0, the description doesn't show up on the other pages, plus there's no 2D symbol column. Also...Is it really possible that a Layout Cad detail allows NOTES but no Note Schedule? How can a simple revision table can be made so time consuming? Back to plain old standard Text, it won't let me down! Link to comment Share on other sites More sharing options...
Kbird1 Posted May 24, 2020 Share Posted May 24, 2020 On 5/22/2020 at 12:31 PM, robdyck said: Also...Is it really possible that a Layout Cad detail allows NOTES but no Note Schedule? Apparently yes I don't usually do "work" in Layout so I had never noticed Schedules can't be made in Layout. So I guess that work would need to be done back in Plan then sent to layout. As for a 2D Image ...No , that is not an Option like other Schedules either. However the Revision table it seems to work fine for me.....but maybe I misunderstand the Issue? ........ however if you don't add the Description when you Add the Revision, you then need to use Edit Page Information on each Page to do it , it you add it when you make the Revision it then populates to the assigned pages eg 1-3 or 1-5 etc.... Mick Link to comment Share on other sites More sharing options...
