BeachHouse1 Posted May 5, 2020 Share Posted May 5, 2020 (edited) Hello All, When adding a door to an exterior wall, an in-swing door is completely different from an out-swing door. But the Door Schedule shows them as the same? Is this supposed to be this way? If so do you have to create a new entry in the library? Thanks. Edited May 5, 2020 by BeachHouse1 Clarification Link to comment Share on other sites More sharing options...
robdyck Posted May 5, 2020 Share Posted May 5, 2020 (edited) It'd help if that wall was part of a room, which would create an inside and an outside. Edited May 5, 2020 by robdyck Link to comment Share on other sites More sharing options...
robdyck Posted May 5, 2020 Share Posted May 5, 2020 And you may want to add the "swing side" column to your schedule. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 5, 2020 Share Posted May 5, 2020 18 minutes ago, robdyck said: And you may want to add the "swing side" column to your schedule. ^^^^This Link to comment Share on other sites More sharing options...
BeachHouse1 Posted May 5, 2020 Author Share Posted May 5, 2020 35 minutes ago, robdyck said: And you may want to add the "swing side" column to your schedule. That did it. Thank you very much. Link to comment Share on other sites More sharing options...
