I cant see my stairs in 2d
Scharp
The only things I can think of are that the layer is turned off or that you are using an invisible line style.  If your layer was off, you should get a message telling you that it is off and asking you if you want to turn it on.
If you want anything other than guesses, you should probably post a simple plan that demonstrates the problem.
If all else fails, then you should contact our technical support team.
