Layout Sheet
HDbyJustin
The architect I am moonlighting for wants the title sheet to be rotated 90° to the rest of the sheets. I am not sure this is possible without creating a new layout just to have the title sheet be in the correct orientation. Is this an accurate assumption?
You will need to create the rotated page layout but it can be done in the same layout file if you are just talking about the "Title Block".
Just open the Layout Page Specification DBX and mark it as "Use as Page Template" and then it becomes another page 0 type template. Then the layout page need to be marked as using that template.
If you are actually rotating the sheet you can do that to as long as they are printed separately.
Huh?  Need a lot more information than that.  What do they want rotated?  If its the sheet, just print the thing up and turn it.  If its the title block, you just need to create a different page template as Chop said.  If its the layout boxes, just rotate them.  If it's some text boxes, just rotate those.
