Light Symbols in 3D
CharlesVolz
Is there any way or trick to create a electrical light fixture with a point light where the point light location is outside of the stretch planes and will move with the light fixture as it is resized? Think of a pendant light where the only stretch planes are in the stem so the light shade can be raised and lowered.
You can place the light source in a fixture anywhere you wish, even outside of the stretch zone. Note that the light source does not change when you alter the size a light fixture even if the light source is within the bounding box. Complained about this several years ago but this issue has not been addressed. If you change a light fixtures size you need to go back in and adjust the light source position manually in the offset boxes.
