No1ZZTopfan Posted April 14, 2020 Share Posted April 14, 2020 Instead of spending hours searching, I prefer to do this. My apologizes. I've designed homes in previous versions of CA. All the way back to 4. Well, computer HD crashed a while back and nearly lost everything. After new HD, installation of CA 12 w/bonus materials, its back to normal. However... When I render anything in any of the 6 houses in version 12 I get this alert window (see pic) telling me it can't find the files on the list. Instead of spending hours replacing each one, I would like to know if there is way to simple delete or restore them back to their default material setting, delete them altogether, anything! I can't seem to do them (delete is dimmed) either for some reason. Thanks in advance. Using CA 12 with all bonus materials. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 14, 2020 Share Posted April 14, 2020 Pretty sure that if you press "Done" without taking any other action all the listed materials will be replace with defaults. Then you can replace the ones you don't like as you work your way through the plan file. Link to comment Share on other sites More sharing options...
Dermot Posted April 14, 2020 Share Posted April 14, 2020 Have you tried installing the bonus libraries listed? https://www.chiefarchitect.com/3d-library/ Link to comment Share on other sites More sharing options...
No1ZZTopfan Posted April 14, 2020 Author Share Posted April 14, 2020 @Chopsaw. No, sir. That did not work. @Dermot. Re-installing the previous version libraries appears to be working. Thanks Link to comment Share on other sites More sharing options...
