Shelves And Partitions Display
Dennis_Gavin
Shelves inside cabinets are not on that layer as they are part of the cabinet symbol.
Reduce the depth of the shelves in the defaults to something used in the real world and the problem goes away. I've set up templates with reduced depth shelves, when I forget and use the wrong template I just go in and make em half depth. Problem with that is they are not a dynamic default and group select usually doesn't work on em.
Been that way since I've had it (X3). Default full depth shelf is from front edge to back with no clearance, just asking for Z fighting. IRL shelves are always set back. Switching doors styles is not really a solution, 80% of clients want a recess panel door. Not the biggest pain since it can be resolved in templates.
