ericepv Posted October 24, 2014 Share Posted October 24, 2014 I am trying to create a herringbone pattern with a hardwood floor (similar to the attached image). I tried specifying the pattern in materials definition window but this only works for vector views not 3d and it also does not have an effect on the plank size. Has anyone else been able to achive this? Link to comment Share on other sites More sharing options...
ericepv Posted October 24, 2014 Author Share Posted October 24, 2014 Oops, forgot to attach the image, here it is. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 26, 2014 Share Posted October 26, 2014 can you not set the pic above as your texture in the materials def. window ? (you may need a better pic though? a seamless texture ) Re the size......I find a lot of Chief's Pattern scales are way off by about 10X usually , set the scale size to 0.1 instead of 1 and try it , or play with it till it measures right, the Siding I just did I had to scale to .166 to make it measure correctly in an elevation. M. Link to comment Share on other sites More sharing options...
ericepv Posted October 27, 2014 Author Share Posted October 27, 2014 Ahh... that was my problem. I imported the picture as an image instead of as a material, thanks for pointeg it out. Link to comment Share on other sites More sharing options...
