size of temporary dimensions
Lighthouse
How do I control the size of temporary dimensions?  I know I can toggle them on and off, but I don't see where I can control the size.  When I'm working on a CAD detail, the temporary dimension appear very large (particularly the hash marks) and obscure what I'm working on.  I would think they would match the size of the dimension default, but they don't.  See the 7/16" temp dimension in the attached pdf.  The hash marks are larger than on the 5" dimension.   thanks!
temp dimension.pdf
My best guess is that your active dimension default does not match the default that is set for the manual dimension line that was drawn.
Select the manual dimension line.  Open it for specification.  What dimension default is it using?
Now open the Default Settings dialog.  Go to dimensions.  What is your currently active dimension default?
If they are not the same, than that is why they look different.
