Window depth in upper pony wall is for lower. How to control?
GeneDavis
A walkout basement has its floor 0 walls done as pony walls, 2x6 framing upper half, 8" concrete stemwall lower half, aligned both at main layer out.
The window I place in the upper wall has its frame of depth for the stemwall, and of course the trim is positioned such.  How to fix?
Do the math and you can see that an 8" stemwall with a 2x4 framing wall, no sheetrock on stemwall side, spaced 1/2" away from the 'crete face, yields a 12" dimension outside stemwall to inside framing wall.  With the wall positioned as I want, with the 1/2" gap, the window won't behave.  Only when I open the gap by another inch, to 1-1/2 away from the stemwall, will the window behave.
I wonder if a room divider wall in that space somewhere, maybe 1/4" inside the stemwall, will change things.
