DzinEye Posted March 26, 2020 Share Posted March 26, 2020 Off-hand, have any of you experienced the two issues I'm highlighting in the stairway? Treads showing through stringer on curved portion of stair, and railing below not filling out with ballusters? This in in X11 and the file is massive, so I'm first trolling for thoughts before posting the plan. Thanks in advance... Mark Link to comment Share on other sites More sharing options...
DzinEye Posted March 26, 2020 Author Share Posted March 26, 2020 25 minutes ago, solver said: Easy to use Edit Area to cut out just the problem part of the plan. I wish it was that easy, unless (and likely) that I'm not doing something right. I get the following when I Edit Area All Floors... and it's even worse with just Edit Area. On the bright-side... it fixed my railing under the stairs!?!? Makes me think it must be related to the floor opening, no? Now about those treads... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 26, 2020 Share Posted March 26, 2020 1 minute ago, DzinEye said: I wish it was that easy, unless (and likely) that I'm not doing something right. I get the following when I Edit Area All Floors... and it's even worse with just Edit Area. Eric was suggesting a method of posting a stripped own version of the plan, not a solution to your problem. Link to comment Share on other sites More sharing options...
DzinEye Posted March 26, 2020 Author Share Posted March 26, 2020 1 minute ago, Alaskan_Son said: Eric was suggesting a method of posting a stripped own version of the plan, not a solution to your problem. Yeah, I realize that, but when I use that method to cut out this portion of the plan, and paste it into a new plan file to send just this area, this mess is what I see, so I didn't bother sending it. Should I send it anyway?...or am I doing something wrong? Link to comment Share on other sites More sharing options...
DzinEye Posted March 26, 2020 Author Share Posted March 26, 2020 46 minutes ago, solver said: Easy to use Edit Area to cut out just the problem part of the plan. I managed to get the floor opening back, but everything's still a mess....but perhaps you can figure out the stair tread issue from this Test_1.7z Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 26, 2020 Share Posted March 26, 2020 Here's what I see... Link to comment Share on other sites More sharing options...
Dermot Posted March 26, 2020 Share Posted March 26, 2020 Have you tried this in X12 yet? The problems with the stair tread related to curved stairs and closed stringers should be significantly improved in X12. As far as the railing is concerned, the program is not able to clip a normal railing to fit under a staircase. You will have to come up with a different method for modelling this. You may want to submit a feature request for this. Link to comment Share on other sites More sharing options...
DzinEye Posted March 26, 2020 Author Share Posted March 26, 2020 5 minutes ago, Alaskan_Son said: Here's what I see... What'd you do?... Did you open it in X12? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 26, 2020 Share Posted March 26, 2020 Just now, DzinEye said: What'd you do?... Did you open it in X12? Yes. I forgot you said it was in X11. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 26, 2020 Share Posted March 26, 2020 I see that you have X12. Is there a reason you haven't just continued the plan in X12? Link to comment Share on other sites More sharing options...
DzinEye Posted March 26, 2020 Author Share Posted March 26, 2020 5 minutes ago, Dermot said: Have you tried this in X12 yet? The problems with the stair tread related to curved stairs and closed stringers should be significantly improved in X12. 1 minute ago, solver said: I see no problems either in X12. Is there some reason you are using X11? Yeah.. I have to share the file with an interior designer using X11... But great to know... I will have to take screenshots from X12. Link to comment Share on other sites More sharing options...
DzinEye Posted March 26, 2020 Author Share Posted March 26, 2020 8 minutes ago, Dermot said: As far as the railing is concerned, the program is not able to clip a normal railing to fit under a staircase. You will have to come up with a different method for modelling this. You may want to submit a feature request for this. Thank you Dermot, I will Link to comment Share on other sites More sharing options...
