HumbleChief Posted March 17, 2020 Share Posted March 17, 2020 Have never been able to reproduce this phenomenon because it's so random but just had feeling it was about to happen so I took a video of it. Anyone else experience this? Thoughts? Ideas? BTW not plan specific. Thanks Link to comment Share on other sites More sharing options...
Dermot Posted March 17, 2020 Share Posted March 17, 2020 The program is working the way it was designed to and it's not really random. By default, the automatic lighting is done on a per room basis. When the camera changes from one room to another the program will turn on the lights in the new room and turn off the lights in the old room. The catch is that the program will only actually update the lighting when something (other than moving the camera) is changed to force it to update. In your video, you very clearly moved the camera through your rooms but the lighting did not update until you painted a surface which forced the update. If you want to manually force the update, just hit F5. If you don't want the program to automatically update the lighting per room, then you need to learn how to use lighting sets. 1 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted March 17, 2020 Author Share Posted March 17, 2020 39 minutes ago, Dermot said: The program is working the way it was designed to and it's not really random. By default, the automatic lighting is done on a per room basis. When the camera changes from one room to another the program will turn on the lights in the new room and turn off the lights in the old room. The catch is that the program will only actually update the lighting when something (other than moving the camera) is changed to force it to update. In your video, you very clearly moved the camera through your rooms but the lighting did not update until you painted a surface which forced the update. If you want to manually force the update, just hit F5. If you don't want the program to automatically update the lighting per room, then you need to learn how to use lighting sets. Thank you. Can't say I understand the behavior nor the logic behind it as you have described, but will hit F5 when it occurs again if that's the simple fix. EDIT: Got it to behave as you've described by going in to another room, hit F5, the room lit up, back to original room, lights were off as you've described, hit F5 lights back on. Thick skull penetrated - Thank you. Link to comment Share on other sites More sharing options...
