CARMELHILL Posted March 3, 2020 Share Posted March 3, 2020 I just noticed that every time I export to Rescehck, the windows come in as vinyl frames. I can't recall if this also happened in previous Chief versions. Is there anyway to force Chief to export them as wood framed windows? otherwise you have to change every line item and re-input thei U and SHGC values. Link to comment Share on other sites More sharing options...
Evolution Posted March 4, 2020 Share Posted March 4, 2020 What about the settings in Window Default? Materials etc.? IF all the windows are the same construction? Not sure, but isn't it the default settings that provide the typical information for export? Just guessing 1 Link to comment Share on other sites More sharing options...
robdyck Posted March 4, 2020 Share Posted March 4, 2020 16 hours ago, CARMELHILL said: I just noticed that every time I export to Rescehck, the windows come in as vinyl frames. I can't recall if this also happened in previous Chief versions. Is there anyway to force Chief to export them as wood framed windows? otherwise you have to change every line item and re-input thei U and SHGC values. 1 Link to comment Share on other sites More sharing options...
CARMELHILL Posted March 4, 2020 Author Share Posted March 4, 2020 Thanks guys. I found that default setting. I couldn't find it two days ago. I use windows that I added to my User Library for standard Andersen's that I use constantly. I'll have to go in and change their individual attributes. Weird. I don't ever remember seeing this issue before, but Rescheck itself might have recently gotten an upgrade. Thank you. Link to comment Share on other sites More sharing options...
