Window material in Rescheck export
CARMELHILL
I just noticed that every time I export to Rescehck, the windows come in as vinyl frames. I can't recall if this also happened in previous Chief versions. Is there anyway to force Chief to export them as wood framed windows? otherwise you have to change every line item and re-input thei U and SHGC values.
What about the settings in Window Default? Materials etc.? IF all the windows are the same construction? Not sure, but isn't it the default settings that provide the typical information for export? Just guessing:(
Thanks guys. I found that default setting. I couldn't find it two days ago. I use windows that I added to my User Library for standard Andersen's that I use constantly. I'll have to go in and change their individual attributes. Weird. I don't ever remember seeing this issue before, but Rescheck itself might have recently gotten an upgrade.
Thank you.
