dkmtek Posted February 29, 2020 Share Posted February 29, 2020 Hi All, New topic! I am trying to create Remodeling drawings for a project to present for permit. I can't seem to do it all in one drawing? e.g. Existing walls, Demo Walls, and Proposed walls on the same plan because even with the layers turned off, they interfere with other layers? The Village wants separate sheets (Layout sheets) to reflect the existing, demo (to be removed) and Proposed. I have created different walls for different layers, but, when I work in other layers, they will interfere with what I am drawing in other layers? The only thing I can think of is, work in different "Plans" and send to one "Layout"? Will that work? (Would rather work in one "Plan") David I-Mac on X8 Link to comment Share on other sites More sharing options...
Signatures Posted February 29, 2020 Share Posted February 29, 2020 Welcome It's helpful to know what software you are using as it changes from version to version. It helps others to have this info in your signature so it's always available. Please see this topic for a signature how to. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk 2 2 Link to comment Share on other sites More sharing options...
builtright3 Posted February 29, 2020 Share Posted February 29, 2020 1 hour ago, dkmtek said: Hi All, New topic! I am trying to create Remodeling drawings for a project to present for permit. I can't seem to do it all in one drawing? e.g. Existing walls, Demo Walls, and Proposed walls on the same plan because even with the layers turned off, they interfere with other layers? The Village wants separate sheets (Layout sheets) to reflect the existing, demo (to be removed) and Proposed. I have created different walls for different layers, but, when I work in other layers, they will interfere with what I am drawing in other layers? The only thing I can think of is, work in different "Plans" and send to one "Layout"? Will that work? (Would rather work in one "Plan") David I-Mac on X8 I always do an As-Built drawing and use it for my demo plan and when I start the revisions I save it as new plan. Then you can send each one to layout. Link to comment Share on other sites More sharing options...
SNestor Posted February 29, 2020 Share Posted February 29, 2020 You need to create an "AS-Built" plan...and a separate plan for the "remodel". There are a lot of new features that can help...starting in X11. You should watch the videos Chief put together... Here is an overview video from Chief: https://www.chiefarchitect.com/videos/watch/2442/productivity-features-added-in-x11.html?playlist=156 Link to comment Share on other sites More sharing options...
SNestor Posted February 29, 2020 Share Posted February 29, 2020 1 hour ago, dkmtek said: Hi All, New topic! I am trying to create Remodeling drawings for a project to present for permit. I can't seem to do it all in one drawing? e.g. Existing walls, Demo Walls, and Proposed walls on the same plan because even with the layers turned off, they interfere with other layers? The Village wants separate sheets (Layout sheets) to reflect the existing, demo (to be removed) and Proposed. I have created different walls for different layers, but, when I work in other layers, they will interfere with what I am drawing in other layers? The only thing I can think of is, work in different "Plans" and send to one "Layout"? Will that work? (Would rather work in one "Plan") David I-Mac on X8 Here is another set of videos Chief has on the subject; https://www.chiefarchitect.com/videos/playlists/120/remodeling.html Link to comment Share on other sites More sharing options...
dkmtek Posted February 29, 2020 Author Share Posted February 29, 2020 5 hours ago, Signatures said: Welcome It's helpful to know what software you are using as it changes from version to version. It helps others to have this info in your signature so it's always available. Please see this topic for a signature how to. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk Link to comment Share on other sites More sharing options...
dkmtek Posted February 29, 2020 Author Share Posted February 29, 2020 Signature, Look under my Signature (Name) I-mac on X8 Link to comment Share on other sites More sharing options...
