post to beam
winterdd
  On 2/23/2020 at 1:22 AM, Kbird1 said:
you can make your own out of a P-Solid and then save it as a Millwork Symbol > set option to Newel/Post .
It can be a bit tricky at times getting posts oreintated correctly at corners when they aren't square though.
Expand
very tricky. i tried to rotate in the symbol settings 90 degrees but it won't budge. where is that setting?
  On 2/23/2020 at 3:55 AM, Alaskan_Son said:
Drop that symbol back into the plan, rotate it 90 degrees, and just create a new symbol.  Use the first one as a 6 x 4, and the second one as a 4 x 6.  This basic technique comes in handy when creating 2D Blocks as well.
Expand
that was it.......rotating and then new symbol, thanks
Expand
You can't in Plan once it's in an Auto Rail afaik, but you can Open the Symbol in the Library and rotate 90° it there , then reload the Symbol in the Railing, Newel DBX.
Or use Micheal's method so you have one of each :)
