Larry_Sweeney Posted February 11, 2020 Share Posted February 11, 2020 I have two floor platforms. One sits on top of the foundation wall while the other one steps down 2'. I want that one to be attached to the wall using a ledger. What is the correct procedure to accomplish this? I've search for info on this and up to now I can not find anything for this particular situation. When I frame the floor CA produces what I show in the attachment. When I highlight the foundation wall and check the dbx. "Hang Floor Platform Above on Wall" in Wall Specification CA hangs both "A" and "B" platforms off the foundation wall. I would think Chief should be able to do what I want to do or at least there would be a work around to accomplish it. Thanks in advance for taking the time. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted February 11, 2020 Author Share Posted February 11, 2020 Eric.....................Will send one later. I'm just now heading out the door. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted February 12, 2020 Author Share Posted February 12, 2020 Eric....................After playing around with a simpler plan I've come to realize that the foundation walls attached to the one I wanted the ledger attached to are a factor in making the floor framing work correctly. Without getting into a lot of detail explaining, I figured how to make the floor platform frame very close to what I wanted it to do with just a little clean up. Appreciate your time. Have a great day. Link to comment Share on other sites More sharing options...
Evolution Posted February 12, 2020 Share Posted February 12, 2020 1 hour ago, Larry_Sweeney said: I figured how to make the floor platform frame very close to what I wanted Hey Larry, I know you don't want to do a lot of explaining, but (when you get time) it would be great if you could tell us a little of what you did (work-around, etc) ? Probably asking too much huh? Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted February 12, 2020 Author Share Posted February 12, 2020 Bob......................I have a lot going on today, but I'll try later tonight to put something together. Link to comment Share on other sites More sharing options...
