winterdd Posted February 2, 2020 Share Posted February 2, 2020 Where would I find the option to angle a wall as shown? Doing an addition and would like to make the existing home match on my plans for the client. You can see the windows angled out in the picture. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 2, 2020 Share Posted February 2, 2020 I would need to try it to confirm but I think you could build the wall and frame it with the window and everything then convert to symbol to tilt it. It of course would need to be built over sized so it would still be tall enough when tipped and maybe a little extra since you will not be able to angle the top and bottom plates properly. Otherwise maybe make a symbol window and surround it with p-solids. Side walls can be stretched over to join the sloped gable wall. If not try a search as I am sure there are other discussions on the subject as Chief really does not do angle walls yet. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 2, 2020 Share Posted February 2, 2020 Manually with primitives, by converting a wall to a symbol and using that, or by getting super tricky with roof/ceiling planes. I would just be using primitives. A lot of manual work no matter how you slice or dice it though. Not something Chief was really designed to do. Link to comment Share on other sites More sharing options...
winterdd Posted February 2, 2020 Author Share Posted February 2, 2020 thanks chop, let me give it a try and report back later. Link to comment Share on other sites More sharing options...
winterdd Posted February 2, 2020 Author Share Posted February 2, 2020 1 minute ago, Alaskan_Son said: Manually with primitives, by converting a wall to a symbol and using that, or by getting super tricky with roof/ceiling planes. I would just be using primitives. A lot of manual work no matter how you slice and dice it though. will do, i am searching primitives as well. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 2, 2020 Share Posted February 2, 2020 How is yours done Eric ? It looks good. Link to comment Share on other sites More sharing options...
