Garage and House Angled Away From Each Other
corland1
Hello,
I'm hoping someone has had the same issue looking at the garages and houses oriented away from each other in Full Perspective Overview.
I want the garage to tilt/face the same direction as the house.  How can I make this change?
Thank you,
CJ
Use the edit area tool and select one or the other and set the rotation angle.
Ideally, you want to have these sorts of design decisions made before you start building the model so that you can set the angle, or use temp construction lines to keep everything organized.
