pjbuilder Posted October 14, 2014 Share Posted October 14, 2014 I'm having an issue with the way the lighting in a basement remodel plan. Not looking for perfection just trying to get rid of the bright lights. Not explaining it very well but when you see this raytrace , you'll get the idea. Thanks Yin Revised Entire backup.zip Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 14, 2014 Share Posted October 14, 2014 I didn't open your plan, but it would appear that the light source is in the wrong location for many of your can lights. ie: they are located just above the floor instead of at or above the ceiling. That's not normal as they should be a part of the fixture. Link to comment Share on other sites More sharing options...
Chiefer Posted October 14, 2014 Share Posted October 14, 2014 Adjust UV Roughness to 100% or change Material Class to General Material. If you want a bright ceiling use Ambient Occlusion instead of Uniform Intensity. Link to comment Share on other sites More sharing options...
keithhe Posted October 14, 2014 Share Posted October 14, 2014 Joe and Jintu are the experts, but I simply changed the hardwood from a "polished" to general material and makes a huge difference. I suspect to must have changed it to polished which is the problem. Way too reflective that way. 1 Link to comment Share on other sites More sharing options...
pjbuilder Posted October 14, 2014 Author Share Posted October 14, 2014 Thanks for the help. Changing the floor to matte and/or general materials worked great. Link to comment Share on other sites More sharing options...
