Roof & Exterior Question
jheath21
Hello!
Two questions ...
First one is regarding the photo I've attached. How do I get my wall to extend up to the roof behind the garage?
Second one, how can I get multiple materials on the exterior of my walls? For example, board & batten siding and river rock.
Thanks!
Pull the roof edge back a little and the "attic" wall should generate, or simple draw and attic wall in there.
For multiple wall veneers, open the wall and make a copy call it Siding-4, B&B and change the siding. Now that wall is available whereever you need it.
Those work on all versions back to v.9.5 that I know of.
Does that wall continue down to the floor or is it only between the two roofs?
If you're just doing rough modeling to see how the building will look (not for con. doc's) then it can sometimes be faster/easier to draw 'wall material regions' to show different wall materials.
