Story Pole Text Alignment
EconBlueprints
Hello,
On the story pole dimensions, I like all of the text to be vertically aligned, and all of the markers to be vertically aligned.
I cannot get them both to be aligned; when the markers are aligned the text seems to default to an offset distance from the marker.
Is there a way to align both the text and markers?
Picture of problem is attached.
Thanks in advance,
As Chop said, you can add spaces.  If you are using dimensions below the line this could be solved by using a Marker Default that has the Alignment set to Away From Marker so that the dimension just gets moved with your text.
The other things you can do is manually position actual markers which DO have the capability you're asking for.
