Member Statistics
Similar Content
By DRyeHD
How do I go about putting a roof on this round room only? I've watched the related video and done some searching on line. When I use the Build Roof Planes and try to retain manually drawn roofs (which all other roof planes are) CA puts auto roof planes on top of all the other roof planes.
By MN_JohnH
I can't figure out why my walls are not meeting the roof.
I run into this a lot and usually finagle walls by puling on their handles etc but changing from gable wall to hip wall etc seems to make no difference in how the wall acts.
I just want them to act like when I first drew them where they just automatically connect with the roof.
plan.plan
By DRyeHD
I'm having a problem getting a deck to remain when I try to contain it under a roof. The function of the roofs to the covered deck are to make a covered walkway to the covered deck. I didn't know where to begin searching for this issue so I'm posting this.
The attached screenshot shows where I'm able to get the roof and deck to look right (4'-1") and where the deck room conflicts with the roof (4'-0"). Ideally, I would make these both 4'-0". When I try to adjust the deck rail in or out from the back of the house (shown at 4'-0") the deck disappears.
I have attached the .pln file. Any advise is appreciated.
Ingram2.zip
By mprovost129
Ever since I upgraded to X14 I've had an issue where the trim doesn't populate on some of my roofs / roof belts. Has anyone else had this issue? Maybe I should try reinstalling X14? These roofs were copied from the adjacent roof that has the trim and has the same properties. It just makes no sense. I sent a request to support, and they couldn't recreate it at the time.
220804 - Krupa Residence - Lot 8C The Preserve at Brook St. Rehoboth, MA.zip
