BWoods Posted January 10, 2020 Share Posted January 10, 2020 I'm working in Chief Architect Premier X11 and would like to put a dimension in without the number from the dimension, just my own text for a "height to be determined" scenario. I see I can add the leading/trailing text segments, and also that I can make it a blank segment, but that gets rid of all the text as well as the number. Surely there's a better solution that to just draw my own dimension lines. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 10, 2020 Share Posted January 10, 2020 Multiple options, but here are the two that I usually use depending on the scenario... 1. Decrease the text/number height for that dimension to at or near zero and just manually position the text over the top. 2. Use a single segment polyline with arrows on both ends and place your text into the polyline label. 1 Link to comment Share on other sites More sharing options...
BWoods Posted January 10, 2020 Author Share Posted January 10, 2020 Solution 1 will work for me. Thanks! Link to comment Share on other sites More sharing options...
Richard_Morrison Posted January 10, 2020 Share Posted January 10, 2020 This is also one the improvements listed for X12. Link to comment Share on other sites More sharing options...
DzinEye Posted January 10, 2020 Share Posted January 10, 2020 19 minutes ago, Richard_Morrison said: This is also one the improvements listed for X12. Yes!.. I noticed that too. Good to see it coming. Link to comment Share on other sites More sharing options...
