PRINTING LAYOUT AND PLAN LINES COME OUT IN PREVIEW & plot THICKER THAN
mainst555
It’s good to make sure your plan and layout line settings are the same or your lines will print really thick.  Typical is 1:100mm.  You find it in print> page layout settings.
It also helps everyone if you have your signature setup with your info of program and hardware as sometimes the suggestions will be different.
