crosscutter55 Posted December 27, 2019 Share Posted December 27, 2019 I am using x10 full . Is there a way to modify the existing size of the concrete stairs in the library to match the dimensions i need , and if so how would i start Link to comment Share on other sites More sharing options...
Kbird1 Posted December 27, 2019 Share Posted December 27, 2019 1 hour ago, crosscutter55 said: I am using x10 full . Is there a way to modify the existing size of the concrete stairs in the library to match the dimensions i need , and if so how would i start They are a symbol , Fixture in this case, so they resize like most symbols on the general tab , however you can only have 4 steps , since that is how it was made. Use the Stairs off the Stair Menu/Icon instead and draw your own and specify everything like the number of treads , their size,materials etc etc instead. M. Link to comment Share on other sites More sharing options...
Evolution Posted December 27, 2019 Share Posted December 27, 2019 Watch this video, then believe you can place your stairs using the stair tools and edit their materials etc. to have the concrete stair you are after. if you don't want the risers to be sloped, you can just change the materials to concrete after you've placed them and have the size (width, height, treads and risers) as you need it. Hope this helps. https://www.chiefarchitect.com/videos/watch/384/drawing-concrete-stairs-with-sloped-risers.html Link to comment Share on other sites More sharing options...
crosscutter55 Posted December 27, 2019 Author Share Posted December 27, 2019 that video seems to help alot !!! However i do not see anywhere that they address the stringers on the left & right of the stairs Link to comment Share on other sites More sharing options...
crosscutter55 Posted December 27, 2019 Author Share Posted December 27, 2019 i can not see how to eliminate the stringers Link to comment Share on other sites More sharing options...
Kbird1 Posted December 28, 2019 Share Posted December 28, 2019 On 12/27/2019 at 12:02 PM, crosscutter55 said: i can not see how to eliminate the stringers You don't need too Chief will, when you uncheck the open underneath check box, set 0" overhang on your treads and then just make all the materials concrete and you will see Chief removed the Stringers as the Stairs are actually hollow . You can also turn on/off Railings if wanted. Link to comment Share on other sites More sharing options...
crosscutter55 Posted December 28, 2019 Author Share Posted December 28, 2019 Thanks for all the help !! Sometimes i stay away from chief for long periods of time & when i use it again it is another learning curve !! When i was using the wood stairs i didnt see anything that let me modify the stringers :( in that box related for the adjustments :( but when you go to different camera views it does show up . Link to comment Share on other sites More sharing options...
