rembocanoe66 Posted December 24, 2019 Share Posted December 24, 2019 I've used CA for years and AutoCAD since 1985. (Yeah I'm old). In Florida we do a lot of Block house plans. (CMU) 8x16x8 concrete blocks. Other than manually placing block patterns. Does anyone have an easy way to do wall fill patterns to show the ACTUAL CMU BLOCK Pattern in plan view. It would be great if it actually placed filled cells required for all window/door openings and corners. Any suggestions? Thanks Ray Link to comment Share on other sites More sharing options...
winterdd Posted December 26, 2019 Share Posted December 26, 2019 On 12/23/2019 at 10:16 PM, rembocanoe66 said: I've used CA for years and AutoCAD since 1985. (Yeah I'm old). In Florida we do a lot of Block house plans. (CMU) 8x16x8 concrete blocks. Other than manually placing block patterns. Does anyone have an easy way to do wall fill patterns to show the ACTUAL CMU BLOCK Pattern in plan view. It would be great if it actually placed filled cells required for all window/door openings and corners. Any suggestions? Thanks Ray I asked this same question recently and apparently there isn't a way. I was asking for wall sections. What you may can do is insert a cad block from the library, explode it and use what you need. Thats what i did and it worked great. Link to comment Share on other sites More sharing options...
rembocanoe66 Posted November 7, 2022 Author Share Posted November 7, 2022 So here it is a couple years later. Has anyone found a way to show blocks in plan view for the wall pattern? Thanks Ray Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 7, 2022 Share Posted November 7, 2022 Create a CAD Block. Multi-Copy over your Wall @ 16" o.c. That's probably the easiest way. Note that the Chief Core Library has some Detail Blocks for CMU but they are for vertical detail sections. You would need to create CMU Plan View CAD Blocks: 8x8 8x8 Filled 8x16 8x16 Filled etc. "Multi-Copy" and "Distribute along Line" are the tools I would use but it might also be possible to create a "Fill Pattern" to use as Wall Hatching. AutoCAD Fill Patterns can be imported. Link to comment Share on other sites More sharing options...
