ChiefJSHomesInc Posted November 19, 2019 Share Posted November 19, 2019 Question for you all about text or dimension. When you are drawing a floor system for instance and I add text - it always defaults to the "text" layer - but I have a text layer set up as "text floor joists" - how do you have it default to that layer? Same question would apply with dimensions. Link to comment Share on other sites More sharing options...
javatom Posted November 19, 2019 Share Posted November 19, 2019 Create layer sets that are specific to that view and make an annotation set that applies text to that layer. You can then set up a plan view set that uses just those layers when you send it to the layout. Link to comment Share on other sites More sharing options...
JJohnson Posted November 20, 2019 Share Posted November 20, 2019 9 hours ago, ChiefJSHomesInc said: Question for you all about text or dimension. When you are drawing a floor system for instance and I add text - it always defaults to the "text" layer - but I have a text layer set up as "text floor joists" - how do you have it default to that layer? Same question would apply with dimensions. Learn anno sets and plan view sets of course. Meanwhile, make one text box assigned to that layer you want, and copy it to a few places on your drawing. Open them one by one and place proper text. For arrows, Text Line with Arrow drawn with its tail end snapped to a text object will be placed on the same layer as the text object and inherit all of that layer’s attributes Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 20, 2019 Share Posted November 20, 2019 Click on Help and search Multiple Saved Defaults Link to comment Share on other sites More sharing options...
ChiefJSHomesInc Posted November 21, 2019 Author Share Posted November 21, 2019 Thanks all for your help!! Link to comment Share on other sites More sharing options...
