fangelo
Exterior door with storm or screen door
Does anyone have, or know how to create an inswing exterior door with an out-swing storm or screen door?
Please post questions in General Q&A.
Symbols and Content
Post links to and discuss your symbols, textures, or other Chief-related items here and share them with other Chief Architect users.
  • Downvote 1
You can place 2 doors in the same location.
If you are using X11.
Thanks, Glenn & Chopsaw, the two doors at same location worked great
    27499
    Bren0625
    Bren0625
  • Similar Content
    • By cjanderson66
      I have a client that is requesting a (4) panel sliding Nana wall that will slide into a wall.  Has anyone created one?  This would be with a 4" exterior wall with a (4) panel slide by into a 10" wall with another 4" interior wall.  Trying to figure out the best way to create one.
    • By MichaelaS
      Looking for a way to add window and door toppers for interior millwork.
    • By Designer100
      1)I need to create a 3' x 6'8" with 1'4" Transom. I need it to look Similar to attched picture as a 36" width door.
      Would appreciate any help. Bedroom 2 entry door was one I was trying to make , then copy it other places. trim overlaps door on top.
      2) Also home is 24" off grade built up under slab. any suggestions appreciated.  second floor will be left unfinished for future build out .
      3) garage door into house is showing below 24" raised for ada lift and steps.
      Thanks for any help.
      Newell
      newell.cheatheam@gmail.com
      713.385.3622
      Richie_house._La.plan
    • By StructEng58
      Hello All,
      I am working on a plan for an addition and in the basement there is a garage with an overhead door and man door. The doors show up on the 3D overviews and elevations, but not the foundation plan. I have checked the layers and they are all on. The odd thing is that I have layer called Doors, Existing and they are showning fine everywhere. Note the new doors do show up on an older version of the plan (backup copy).
      Any suggestions would be appreciated.
      Thank you in advance,
      Chris
    • By CGC_LLC
      I have a 3-4 door opening that I want to place a double 1-8 hinged door into.  I can't seem to find an option in the door specification menu that will allow me to make the door a double door.  It just automatically places a single door that is 3-4.
