Strange anomoly in render views
Evolution
Anyone had this happen?  I thought I had painted a color on a library object (without knowing it) but I can't get the strange (grayish) color to go away. I checked the symbol, etc., (a tub shower from the library) it is supposed to be white in the object DBX, and is to some degree. The strange color has also bled into part of a near by door.. no matter what render style I use it shows up?
I thought it was a shadow, but no matter which way I move the camera it is still there.  Video card?  But this is the only item / time it has happened.
YARBRO RESIDENCE ADDITION ROOF OPTION 2.zipFetching info...
  On 10/23/2019 at 7:53 PM, TheKitchenAbode said:
They are shadows from something, just open up your camera DBX and uncheck shadows, they disappear. I looked around your plan and there are many areas where there are major gaps in the ceilings and walls extending into the attic. This is most likely causing the problem.
Expand
that fixed it, thanks Graham!  I still have to clean up some things on the inside.  I'm working on finding what's causing the gaps.
