Evolution Posted October 23, 2019 Share Posted October 23, 2019 Anyone had this happen? I thought I had painted a color on a library object (without knowing it) but I can't get the strange (grayish) color to go away. I checked the symbol, etc., (a tub shower from the library) it is supposed to be white in the object DBX, and is to some degree. The strange color has also bled into part of a near by door.. no matter what render style I use it shows up? I thought it was a shadow, but no matter which way I move the camera it is still there. Video card? But this is the only item / time it has happened. YARBRO RESIDENCE ADDITION ROOF OPTION 2.zip Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted October 23, 2019 Share Posted October 23, 2019 They are shadows from something, just open up your camera DBX and uncheck shadows, they disappear. I looked around your plan and there are many areas where there are major gaps in the ceilings and walls extending into the attic. This is most likely causing the problem. 1 Link to comment Share on other sites More sharing options...
Evolution Posted October 23, 2019 Author Share Posted October 23, 2019 56 minutes ago, TheKitchenAbode said: They are shadows from something, just open up your camera DBX and uncheck shadows, they disappear. I looked around your plan and there are many areas where there are major gaps in the ceilings and walls extending into the attic. This is most likely causing the problem. that fixed it, thanks Graham! I still have to clean up some things on the inside. I'm working on finding what's causing the gaps. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted October 23, 2019 Share Posted October 23, 2019 Pleased to have helped. Yes, I realized you still had work to do, just indicating that these openings can be problematic when rendering. Link to comment Share on other sites More sharing options...
Evolution Posted October 24, 2019 Author Share Posted October 24, 2019 5 hours ago, TheKitchenAbode said: Pleased to have helped. Yes, I realized you still had work to do, just indicating that these openings can be problematic when rendering. You knew what to look for.....I sure didn’t. Link to comment Share on other sites More sharing options...
