kwhitt Posted October 22, 2019 Share Posted October 22, 2019 I've got a screened porch adjacent to an open deck where the posts/railings need to meet up - see images attached. How do I get the posts to line up? When the converging walls snap together, the post is offset. I've spent the last 30 minutes messing around with this. I probably should have drawn them manually if this is the best CA's tools can do... I'd appreciate any advice. Thanks. Link to comment Share on other sites More sharing options...
kwhitt Posted October 22, 2019 Author Share Posted October 22, 2019 Here's the plan. CHF_Chin Proposed_10-22-19_PROPOSED.rar Link to comment Share on other sites More sharing options...
Chopsaw Posted October 22, 2019 Share Posted October 22, 2019 Hi Kevin, Give this a try. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted October 22, 2019 Author Share Posted October 22, 2019 Hey Chopsaw. That's brilliant. Thank you very much for the solution. I did find another way by using straight railing on top of the deck. It wasn't as easy as your solution though. Thanks again! Kevin Link to comment Share on other sites More sharing options...
