kwhitt
Converging Deck Posts
I've got a screened porch adjacent to an open deck where the posts/railings need to meet up - see images attached.  How do  I get the posts to line up?  When the converging walls snap together, the post is offset.  I've spent the last 30 minutes messing around with this.  I probably should have drawn them manually if this is the best CA's tools can do...  I'd appreciate any advice.  Thanks.
Hi Kevin,  Give this a try.
Hey Chopsaw.  That's brilliant.  Thank you very much for the solution.  I did find another way by using straight railing on top of the deck.  It wasn't as easy as your solution though.  Thanks again!  Kevin
    28119
    GeorgeWood
    GeorgeWood
