CoolHandLuke Posted September 25, 2019 Share Posted September 25, 2019 I need to keep the second story floor level the same even though part of it is over a 9 foot ceiling for most is over a 10 foot ceiling. In this plan Bed 2 will drop down to meet the ceiling height of the first floor kitchen. But that leaves it down relative to the rest of the 2nd story floor. If I put the 2nd floor back to where it matches then the kitchen will change also. Pyron 092519 Roof Planes.plan.zip Link to comment Share on other sites More sharing options...
robdyck Posted September 25, 2019 Share Posted September 25, 2019 @CoolHandLuke There are a few options for this. A shelf ceiling set a 109 1/8" will work. Main floor walls between the 9' & 10' ceilings will need to be adjusted to 'ballon through ceiling above' or dragged up manually. You could also add a layer to the ceiling structure on the 9' side. Link to comment Share on other sites More sharing options...
Dermot Posted September 26, 2019 Share Posted September 26, 2019 I would try a search for dropped ceilings: https://www.chiefarchitect.com/support/category/26/ceilings.html In particular: https://www.chiefarchitect.com/support/article/KB-01050/manually-framing-a-dropped-ceiling.html Link to comment Share on other sites More sharing options...
