Change wall hatch default
agenoarch
What I currently do is to create custom wall types where I can dictate the fill or lack of fill at will, for instance the City of Austin, Texas (where I live) requires that demo walls in as-built/Demo plans be solid black and in proposed remodeling plans that the same fill is used to show new construction walls in proposed plan views, so that is what I do for them which basically does what you want but NOW. I always create two separate plans for each remodeling project so each plan file then shows what the Plan Checker at the Permit Authority sees what he or she wishes to see.
select:
>Defaults
>Walls
>Exterior Wall (for example)
>Edit
>Wall Types
from drop down menu select the wall you want to edit (Siding-6, for example)
>Define
double-click on the fill for the main layer to open the Layer Fill Style dialogue
under Pattern and Type select >Solid
under Appearance, select desired color and transparency
>OK
