Sign in to follow this
cjanderson66
CUSTOM ARROWS
Does anyone know how to create custom arrows for leaders.  I know Chief has many different arrows to select but I am still old school and like the thick arrows that I used to draw that are Architectural.  This has been one of my pet peeves is keeping my drawings looking Architecturally hand drawn i.e. text, line weights dims, and arrow are key.
Chief actually has 4 left slash and 4 right slash arrows for dimensioning.  They are 4 different line weights and you can set the arrow you want & its size in the Dimension Defaults.  I like to use the middle (#3) weight right slash with a size of 2"-5" depending on the dwg scale.
    28830
    BethCBD
    BethCBD
  • Similar Content
    • By rembocanoe66
      I've used AutoCAD since 1985 and CA for the last decade. But I've always been stuck on this one thing.
      I understand that I can change the default txt sizes in the default settings. and I can modify the annotations that delineate font characteristics. But when I have an EXISTING line label (in this case a Terrain perimeter indicating the property line)  how do I change the label text heights without redrawing the line?
    • By KINGSTONDRAFTER
      I frequently transfer Chief files between my PC & Laptop.  Consistantly when opening files after transferring, the width of text has contracted by a space and forces a 2nd text line to be created.  This happens in both plan and layout files.  If I then select all the text on a plan or layout and open, and then close, the text widths correct themselves and all is okay.  Annoying. Any ideas or remedies?   Thanks Glen
    • By divreig
      Anyone know how to change label text size? I am working on a large building and the layout scaling is 1/32". The labels are too small and cant be read. I cant find options for text size all the label panel, all it has that box that says use default, that I can check and uncheck. But don't know where to edit this default size or the individual label text size.
    • By Ridge_Runner
      I am having a problem with Rich text adding double arrows, one on each line segment. It just started doing this in X10. I have looked in Help and looked thru numerous pages on Search and find no option to even add a second arrow, much less turn it off! Very frustrating. Anyone know how to change this to just one arrow? One old topic suggested the Connect Line Segments might be turned off, but that is not the case; I checked and it is On.
    • By trentsbc
      Is there a way in Chief to do a multiple copy/replicate object of a text object and have the ability to auto update the text? Specifically, I need to multiple copy text and need it to update the text from 250 to 251 etc. I need to do this hundreds of times. :/
