Box Window Again
kwhitt
I'm modeling an as-built that requires a box window.  The framers forced the window to fit into the box and butchered the vertical casing as shown in the first photo.  I am unable to recreate this in CA as it won't let me make the window any wider which I was hoping would force the casing into the wall thereby making it appear to be cut.  I changed the rough opening on the sides to zero.  This allowed me to increase the width a bit, but still not wide enough.  Is there any way to override the max window width while using a box window or another workaround?  Much thanks, Kevin
By the way, just as a side note, I personally pretty rarely use the box and bay window tools.  They're quick and easy for basic scenarios sometimes, but for anything out of the ordinary, I commonly find the need to just model them manually using walls, windows, room definitions, etc.
