SNestor Posted September 3, 2019 Share Posted September 3, 2019 Is there anything I can do to either reduce or eliminate the lines the column moldings are producing in vector view? I did convert the curve to a polyline...and divided the circle into very small parts...but it doesn't seem to help. Any ideas would by great. Thanks. Here's a couple pics...a sample plan is attached also. (Column Molding in Vector View.plan) Link to comment Share on other sites More sharing options...
kwhitt Posted September 3, 2019 Share Posted September 3, 2019 Don't know if this will work in CA, but in other software that I've used (FormZ, Sketch & Toon module in Cinema 4D), the smoothing angle setting dictates what lines get drawn. You could try setting the angle to a higher number and see if that helps. That said, CA is unlike any other software that I've used! Link to comment Share on other sites More sharing options...
kwhitt Posted September 3, 2019 Share Posted September 3, 2019 What do you know. It does work. I changed it to a library symbol and set the smoothing angle to 60. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted September 3, 2019 Share Posted September 3, 2019 Eric - I am familiar with the smoothing angle settings which is why I mention converting it to a symbol. I would upload the file, but it fails for some reason. Just try it - it really does work. 1 Link to comment Share on other sites More sharing options...
SNestor Posted September 3, 2019 Author Share Posted September 3, 2019 1 minute ago, kwhitt said: What do you know. It does work. I changed it to a library symbol and set the smoothing angle to 60. I knew about the smoothing angle but forgot to make the edit....thanks so much for your help! Link to comment Share on other sites More sharing options...
kwhitt Posted September 3, 2019 Share Posted September 3, 2019 Here you go... Column Molding in Vector View_02.plan Link to comment Share on other sites More sharing options...
kwhitt Posted September 3, 2019 Share Posted September 3, 2019 Steve - Glad I could be the one helping for a change! Link to comment Share on other sites More sharing options...
kwhitt Posted September 3, 2019 Share Posted September 3, 2019 2 minutes ago, solver said: I just converted to a symbol, no change in the smoothing angle. That means that the default setting of 20 degrees plus is adequate to create the necessary phong smoothing. It is still all about the smoothing angle. Has always been in all the CAD software I've ever used. Evidently, CA doesn't assign smoothing to program-created geometry unless designated as a symbol. When you lower the smoothing angle to 1 in the library, it becomes quite heavily segmented. Link to comment Share on other sites More sharing options...
