Corner Window
Designer1
Have corner window functions changed in X11?  It use to be drag two identical windows to the corner, push them together in the corner and uncheck corner post.  Now if I do that, even on a new default plan just trying it out, it grays out the option to uncheck corner post.
Since bifold doors dont allow for corner fuctions without corner post I normally would delete all the glass out of the window and do some alterations to make this work.  Now bringing forth an older plan from a couple versions ago the window procedure worked great but I can no longer do it this way.
How do you all do corner windows and doors in X11?
Thanks!
