Dimensions and Area Square Footage Calculation
sowle-design
When I draw a 10’-0” x 10’-0” room and the Living Area shows 1,137SF? What am I doing wrong!? Also on same drawing the dimension thread shows 10’ in one direction and 9’-39” in the other?  It is seriously driving me insane.  I’m a newbie, please let me know how to address these issues. Thank You!
  On 8/25/2019 at 4:04 PM, sowle-design said:
I opened up X8 and it’s not exhibiting the same issues.  So should I uninstall X10 and reinstall?
Expand
If you have nothing customized reinstalling might be a logical solution.  If it is your unit conversions they are in preferences and will not be packaged with a posted plan although it would eliminate that as a potential factor.  It appears to be that your posted room is 10m rather than 10 ft which explains the 1137 sq ft.  Have you or anyone else tinkered with the unit conversions since the program was installed ?  You could check the unit conversion setup in X8 and it should be the same in X10.
