GlenheadK-B Posted August 17, 2019 Share Posted August 17, 2019 Drawer & Door cabinet hard wear floating off face of cabinets. Any fixes? Link to comment Share on other sites More sharing options...
GlenheadK-B Posted August 17, 2019 Author Share Posted August 17, 2019 X-11 Interiors Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 17, 2019 Share Posted August 17, 2019 Please post your plan - or at least a picture. Generally the hardware is set to be attached to the doors or drawers at the thickest part. If you are putting them on a recessed panel you will need to offset the hardware origin. Link to comment Share on other sites More sharing options...
GlenheadK-B Posted August 17, 2019 Author Share Posted August 17, 2019 Thanks Joe I can see that that is the issue. Link to comment Share on other sites More sharing options...
GlenheadK-B Posted August 17, 2019 Author Share Posted August 17, 2019 Which Origin needs to be offset? Link to comment Share on other sites More sharing options...
Chopsaw Posted August 17, 2019 Share Posted August 17, 2019 32 minutes ago, GlenheadK-B said: Which Origin needs to be offset? You will need to put the symbol of the pull into your user library so that you can edit the "Y" origin offset something like this in your situation. Link to comment Share on other sites More sharing options...
GlenheadK-B Posted August 17, 2019 Author Share Posted August 17, 2019 Thank you! Link to comment Share on other sites More sharing options...
