Library window display issue [RESOLVED]
Larry_Sweeney
     I open CA this morning to a project and went to my library to search for a item, Opening my user library, I went to a folder, clicked on it, and none of the items show in the display window to the right. The only way the items are displayed is to click on each individual item in the selected folder. Everything worked fine yesterday when I closed CA. I went through other sections in my library and nothing is displaying when I click on a folder. What am I missing? What changed since yesterday?
Are either of these items unchecked in your library(under the library browser)? re-check them
1371011056_libprevConsumer.png.cffd872fa5c37637b75a2860887975f8.png314501028_libprev2Consumer.png.184799e65752cc7b63870e514ed4edae.png
They are both checked.  94944374_DISPLAYWINDOW.thumb.JPG.b4224f89fe88418bd80bf283a7817459.JPG  As far as I know nothing I've done is different from when it was displaying correctly yesterday. The one thing I have realized since I opened this thread is when, let's say, I'm in the window dbx. and I go to the library to pick out a casing, my items display in the boxes when only clicking on the main folder.  619242777_LIBRARYDISPLAYWINDOW.thumb.JPG.ffe5b45caa663c0a300120a78a401e3b.JPG  It seems they only don't display when I open the library just arbitrarily to look for an item. Does this help any to my dilemma?
You have inadvertently shrunk your selection pane to the top of the preview screen. If you drag your mouse over the top of the selection preview window your mouse cursor should change to this icon:
when it does, simply click and drag down to set the size of the selection window.
Alternatively, you can deselect and re-select the "show/hide preview panel" icon as mentioned above and it will reset your "selection panel"
If this solves your issue and you feel so inclined, edit your post to include [solved]
cheers!
cheers!
Rene....................Thank you----that was the problem. I have no idea how that happened, but "problem solved!!"
Eric.................When searching earlier threads I had seen where you mentioned "resetting side windows", but in doing a search in "Help" I could not find the subject. I was hoping you would chime in on that subject. Now I know where that option is.-----Thank you.
To All.................Have a great day and thank you for taking the time to help.
awesome, glad to help, if you wouldn't mind editing your topic to add [solved] it will help other people find it :)
