RocioBuild915 Posted August 13, 2019 Share Posted August 13, 2019 How do you create different level depths when designing pools with terrain feature? How do you add beach entries and step transitions into pool side by side? Pool entry starts at FG, slopes/drops to 3' and drops/slopes to 6'. How do you make the transition to appreciate it in the render and for cross sections. Quote Edit Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 13, 2019 Share Posted August 13, 2019 You will have to build the pool out of solids using the Boolean operations. Then make it a symbol that creates a hole in the terrain. The water can be a thin semi-transparent surface with a water texture. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 14, 2019 Share Posted August 14, 2019 It can also be done with Foundation Walls and "rooms" with ceiling heights making the "depth" , for a sloping floor you may need to use a Ramp though. I don't think Terrain Features will show in a Cross Section well ( if at all???) which is why I did it this way......... Link to comment Share on other sites More sharing options...
