2nd floor at Attic under roof issue
Designer100
I do not even have client yet. But contractor roughly gave me info. I need the 2nd floor living area to be under roof of this metail bldg. with 16 ft eave ht. I was making 1st floor ceiling under living area at garage 2 area and then garage area 1 open to steel rafters. When I make a bldg. section it is not putting cabinets and room where it is surpose to be. I want it to be like attached elevation. when I make the garage area to ceiling 11' then it changes the whole right side of bldg. eave ht.
I would apprciate any help.
Thanks,
Newell
Starr.Cole Seabrook Metal Bldg.plan
Looks like your second floor is in the attic space.  Select those walls/fixtures, cut them (ctrl-X).  Go to main floor, set your heights as you want.  Build a second floor.  Paste then hold in place.  I did this and items appear to place normally on the new 2nd floor (room definitions etc).  I did delete the windows (maybe they were manually set), then placed new windows which did position according to my default settings.
Chief Architect does not allow living space to be created in "Attic Space" <A>, not now, not ever, it is not programmed to allow that to occur. I agree with Madcowscarnival in that you should make a "save-as" copy of your plan, delete the objects currently on your "Attic Level", then build an actual second floor under the existing roof, straighten up the settings and then you can copy-paste-hold position the furniture and cabinetry from your failed plan to the new copy, so not all your prior work is then lost.
    30212
    Monikafb
    Monikafb
  • Similar Content
    • By CCOTEY
      Hello,
      I'm new to chief architect and I'm having trouble with this tricky sloped wall. For some reason this weird cut out that reflects the shape of the stair railings is showing up on the ceiling. If anyone has recommendations on how to fix this please share! Thanks
    • By Designer100
      All garage ceiling is surpose to be 10 ft. ht. For some reason the second floor a stair landing, pantry, closet, bath is not level with ceiling of the rest of the 2nd floor. I would appreciate any help
      Trying to get to client tomorrow. Need to finish prelim. plans.
      Newell
      ver 12 ca
      cooper NEW.zip
    • By ChiefuserMathews
      Hello, is there a way to display the ceiling elevation (height) on plan view, as we typically show them on architectural drawings?
      Hello, Is it possible to create a ceiling assembly schedule in CA? I could not find one, nor an option to assign to a custom schedule. Any tips?
    • By Designer100
      can anyone explain how and help me enclose between this new gable roof and ceiling. Also looking toward house thru gable closing in with Hardi-siding. The old roof is showing thru and something else when I do a rendering (see attached). Need to look good for a client in 3 D. They are adding a roof over existing 10' x 20' patio.
      thank you if you can help.
      Newell Cheatheam
      CA 12
      newell@newellcheatheam.com
      Patio Remodeling.plan
