alikelly Posted July 27, 2019 Share Posted July 27, 2019 How do I add a new CAD line that is thicker? Also when I click on a CAD line and try to change the weight it doesn't get thicker. Is there a trick I'm not getting? Thanks! Link to comment Share on other sites More sharing options...
Chopsaw Posted July 27, 2019 Share Posted July 27, 2019 Sounds like you have not found the line weight toggle yet . Link to comment Share on other sites More sharing options...
alikelly Posted July 27, 2019 Author Share Posted July 27, 2019 I see one when I click on the cad line, but when I change the weight, the line doesn't change. Can you tell me where I am supposed to do this? Link to comment Share on other sites More sharing options...
alikelly Posted July 27, 2019 Author Share Posted July 27, 2019 Found it thank you! Link to comment Share on other sites More sharing options...
Chopsaw Posted July 27, 2019 Share Posted July 27, 2019 You can also preset the line weight by adjusting the line weight for your current cad layer. Link to comment Share on other sites More sharing options...
Dermot Posted July 29, 2019 Share Posted July 29, 2019 You can also turn on Print Preview to see your line weights. The advantage of the print preview mode is that it also shows you your page layout. It can be useful to adjust your line weights for the page scale that you expect to print out at otherwise you may not get the results you expect. 1 Link to comment Share on other sites More sharing options...
