KailuaDesigns Posted July 12, 2019 Share Posted July 12, 2019 I am working on a design using 3 Form ceiling materials and they offer dwg files and revit files which I assume are the actual shapes to use in the drawing. Can Chief Architect Interiors 11 open either of these files? It doesn't work when I try to import them as a dwg the typical way although I have done that in the past with other files. Link to comment Share on other sites More sharing options...
MarkMc Posted July 12, 2019 Share Posted July 12, 2019 1 hour ago, KailuaDesigns said: I am working on a design using 3 Form ceiling materials and they offer dwg files and revit files which I assume are the actual shapes to use in the drawing. Can Chief Architect Interiors 11 open either of these files? It doesn't work when I try to import them as a dwg the typical way although I have done that in the past with other files. Took a look, different. Near as I can tell all of the dwg files are 2D which will not make a symbol if that is what you are after. AFAIK there is no way to convert Revit symbols without having Revit (if anyone knows I'd love to hear?) Rummaging around there is one file zip file with a few 3DS files in it. IF any of those are what you are after they work. The file is 3form_shapes_files_3ds_format.zip. What it has in it: For any of the others you would have to start with something 2D and make a symbol from that. IF you have CAD details in Interiors (I know you don't have detail from view)-would be CAD, CAD detail management-new. You can bring in a 2D dwg and start from that. Bit of work though. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 13, 2019 Share Posted July 13, 2019 18 hours ago, MarkMc said: AFAIK there is no way to convert Revit symbols without having Revit (if anyone knows I'd love to hear?) ArchiCAD can do it too. Link to comment Share on other sites More sharing options...
KailuaDesigns Posted July 14, 2019 Author Share Posted July 14, 2019 Thank you Mark, I do have cad details in Interiors so I can experiment with that. I will also track down the files you did find, they look like the shapes I need! Link to comment Share on other sites More sharing options...
