TDS_Drafting Posted June 20, 2019 Share Posted June 20, 2019 How do I get the Reference Floor Layer Set option to show up in the Layer Set Manager dialog box? I'm running X11 and have no idea if chief got rid of that option or if I just can't find the check box that says, "display this". The Help window was no help. Just told me what it is and what it does. Link to comment Share on other sites More sharing options...
SNestor Posted June 20, 2019 Share Posted June 20, 2019 45 minutes ago, TDS_Drafting said: How do I get the Reference Floor Layer Set option to show up in the Layer Set Manager dialog box? I'm running X11 and have no idea if chief got rid of that option or if I just can't find the check box that says, "display this". The Help window was no help. Just told me what it is and what it does. You probably just need to scroll down further... If the "Reference Display Layer Set" doesn't appear... - Then double click the floor #...this will open the "change floor/reference" DBX. You should see what "ref" set you are currently using. You can even edit this set right in this DBX....just click on the "Define" area of the DBX. Scroll down...you may find it! If not...then, Link to comment Share on other sites More sharing options...
Dermot Posted June 20, 2019 Share Posted June 20, 2019 In X11, you can now display multiple reference floors all using different layer sets. The ability to change which layer set is used for your reference floor display was removed from the Layer Set Management dialog as a result. Unfortunately, our help file was not updated to correspond to the program changes to this dialog. I apologize for any confusion that this has caused. To specify any of the information associated with your reference display, you can use the Change Floor/Reference dialog. The easiest way to get to this dialog is to click on the current floor button for any plan view. You can also modify this information in the Saved Plan View specification dialog if you are using saved plan views. More information about Reference Display and Saved Plan Views can be found in both the help files and training videos. Doing a search on these terms should lead you to the most relevant information. In the future, if you find any errors in the help files, please report them directly to our technical support team. You can report problems here: https://www.chiefarchitect.com/support/ Link to comment Share on other sites More sharing options...
TDS_Drafting Posted June 20, 2019 Author Share Posted June 20, 2019 Thank you to both responses. You have answered my question. Link to comment Share on other sites More sharing options...
